SC- 1st Gen (1992-2000)
100 octane unleaded??
Old 11-06-02, 10:42 AM
CDALTON
CDALTON's Avatar
Default 100 octane unleaded??
A gas station in my area is selling 100 octane unleaded fuel. I have a SC 400 with a Weapon-R ECU upgrade. Can the ECU adjust to a higher octane or would I just be wasting my money??
Old 11-07-02, 02:02 AM
Aznteazer
Aznteazer's Avatar
I dont think a chip would be enough to combust all that rich gasoline.
Maybe if u had a super-charger....
Old 11-07-02, 02:31 AM
strongsail
strongsail's Avatar
octane isn't a measure of 'richness,' it's a measure of the ability to resist preignition (knocking) so it will work in higher-compression engines. I'm no engineer so don't quote me, but it seems that the compression ratio is the deciding factor for octane rating although it is also affected by ignition timing - retard timing (and lose power) to prevent knock - would advancing timing past stock be an advantage? Ouch, stop, too many questions, my brain hurts -
Old 11-07-02, 02:32 AM
lex400sc
lex400sc's Avatar
100-octane will only help you if your compression is in the 11:1 range or higher, otherwise I think it'll only retard your motor's power strokes.
Old 11-07-02, 02:34 AM
strongsail
strongsail's Avatar
and what's the stock compression ratio of the v8?
Old 11-07-02, 02:37 AM
lex400sc
lex400sc's Avatar
10.5:1. BTW that 11:1 figure was just a blind shot in the dark . My point was that compression has to be significantly higher for the recommended octane to jump from 91 to 100.
Old 11-07-02, 02:44 AM
Aznteazer
Aznteazer's Avatar
so doesn't all that conclude to a point where 100 octane is too rich?
Old 11-07-02, 02:53 AM
lex400sc
lex400sc's Avatar
Nah, 100 octane is the opposite of rich, it's lean fuel. Fuel that ends up less combustable due to the retardant additives. That is the point because at high compression, the last thing you want is premature detonation.
Old 11-07-02, 03:05 AM
Aznteazer
Aznteazer's Avatar
Yea..I remember reading about the Octane in this forum long long time ago, but I guess I'm thinking of the term 'combusting' in a different way
Old 11-07-02, 11:21 AM
CDALTON
CDALTON's Avatar
Thanks guys for your replies, I will stick with using 93. Thank's again!!!!
Old 11-07-02, 11:37 AM
DriftGirl
DriftGirl's Avatar
Uhhhhh Ask Weapon R?:eek:
Old 11-07-02, 02:19 PM
Toan Nguyen
Toan Nguyen's Avatar
Default High octane fuels...
High octane fuels are usually only needed if you are pinging or on high compression cars (or low compression with Forced induction, thus creating high compression ) The fuel burns easier thus creating more power. If you put 100 octane in your engine, do a full tank and your car should be more rev-happy. Like a nice surge up to peak power. Jap spec Soarers are supposed to have 100 octane fuel, but the best I can get here in Australia from most gas stations is premium unleaded (98 octane). If I put normal fuel in (standard 93 octane unleaded) the car feels hella sluggish. With the 98 octane I the car feels extremely light, betraying the weight penalty that it should have.
Give it a shot and see how you like it. Higher octane wont damage your engine. Lower will. Reset the ECU at the same time.
Toan.
Old 11-07-02, 02:30 PM
lex400sc
lex400sc's Avatar
JDM Soarers are tuned for 100-octane though, the USDM versions like all others are detuned when they reach the United States
Old 11-07-02, 06:06 PM
CDALTON
CDALTON's Avatar
I tried dropping a e-mail to Weapon-R a couple weeks ago. I did not get a reply. Im going to fill up on the way home from work tonight. I will let you guys know the results.
Old 11-08-02, 12:20 AM
Aznteazer
Aznteazer's Avatar
Dude isn't it going to cost over $80 to fill your car with a 100-octane gas?
Theres a 76 gas-station in Pasadena, CA, that sells the 100-octane racing fuel and they're like $4.75/Gallon.
Quick Reply: 100 octane unleaded??
