Another one of those antenna questions!!!
Hi guys and gals! I have a sc300 with a working antenna motor but no antenna and base. I would like to just make it into the rubber type, fixed, and no telescoping. There are some fellow lexuthiast that have converted to the s2k and whatever else they have. Can any one tell give me some advice on where and what to get. Thanks
http://www.locustom.com/MKIV_antenna.htm
I don't know if we need the amp or not but I have it and it works well. This is the only one I've seen so far that sits almost perfect straight up. All the MDX and S2k conversions lean out away from the body and look like they are either bent or were just glued on.
All you need to make it work is included in the kit except for one little plastic ring from the stock antenna I used because it sat a little more flush.
This wasn't the easiest bolt on mod since it isn't exactly meant to fit our cars perfectly but it can be made very close to perfect with a little creativity (and a slight rearward tilt).
You just splice the harness into our stock wiring. We have extra wire(s) for the raising mechanism that you will no longer need so just tape them up and leave them in the fender.
