Seat memory fix?
Hi,
The 2 preset memories on my 1992 SC400 are no longer working. I can't reset them, the buttons just act dead. Any suggestions?
Here's a picture of it before I had the windows retinted darker.
Has anybody seen that style of Lexus wheel? The pic also shows the tips of old style cat back HKS exhaust that is no longer available. I'm looking to get a little extra sound from it as it's nearly as quiet as stock. Any suggestions for a nice sounding but pretty quiet rear muffler for these cars?
Thanks,
Gary
Thanks,
Gary
For the seat memory, you'll probably have to buy a new seat memory ECU, located behind the side trim piece in the back seat. They use the same ECU modules as LS400s in case you can find one cheaper used.
Lex400SC, Thanks for the info on the ECU.
Emerald, Yes the picture was taken at Alki, good eye. I like your plate.
4HUN, Thanks, I think. I bought the car from the original owner in CA. He purchased the wheels from a display in the Lexus dealership and they were installed on the car before it was driven home. He referred to the original wheels as "Wagon Wheels". I would have preferred the car had original wheels, but that's probably due to many years of hunting down (and paying for) original Mustang parts.
Thanks!
Heh, I guess this is a pretty common problem. I have dual 8-way seats in the front, and the memory set does not work at all for either of them. The seats themselves work fine, as does the steering wheel auto-memory.
Ral
Ral
I remember reading on here that someone had discovered, after removing their door trim, that the controls for the seat memory weren't even plugged in. Guess I'll be taking the door apart as step one, and make sure it's plugged in. Gotta' fix the crack in the window surround anyway...
Guess if that doesn't work, I'll try to procure an ECU. Anyone have any idea how much that's going to cost?
Thanks!
Thanks!
My seat memory does not work. The steering wheel memory does not work. also trunk cannot be opened using the interior button on my SC300.
Any Suggestions?
Thought I might start by checking fuses, disconnecting/reconnecting battery,
Checking wires are plugged in on the drivers' door,
checking ECU
If anyone has any other suggestions, please let me know.
Any Suggestions?
checking ECU
hey Six7390GT, your car is the same color as mine, I think, Silver Spruce Metallic, right? I'm in W. WA too - -
I have a '93 - my seat memory can only be set with the ignition in the run position, shifter in park, foot off the brake. If the buttons are not programmed, they will not beep. If the battery is disconnected, the seat memory is erased.
Memory settings control driver's seat (except for lumbar), side mirrors and steering wheel. Steering wheel has a separate memory that remembers the position when the key is removed, if the auto-retract is turned on.
My seat memory does not work. I have tried setting it as suggested in the response above to no avail. Also trunk cannot be opened using the interior button on my SC300.
Any Suggestions?
checking ECU
Any Suggestions?
checking ECU
Ral
Ral
