SC- 1st Gen (1992-2000)
can someone direct me to thread for bypassing factory amp
Old 06-09-12, 05:35 PM
mmartin888
mmartin888's Avatar
Default can someone direct me to thread for bypassing factory amp
Hey guys, I thought once that I found directions on how to bypass the factory amp located in trunk but now I can not find it. Its a 92 sc400
Old 06-09-12, 06:42 PM
Vwpride12
Vwpride12's Avatar
Pioneer or a nak?
Old 06-09-12, 07:41 PM
FutureSC
FutureSC's Avatar
Wooooo for the search button!
https://www.clublexus.com/forums/lex...b-working.html
Oh, and if that isn't clear enough for all of your head unit wiring needs, the amp is directly under the stock CD changer.
Welcome to the club
Old 06-10-12, 02:57 PM
mmartin888
mmartin888's Avatar
its a Nak. I want to install a new amp but keep factory head unit. I saw the really nice write up but did not see where it talks about bypassing factory amp. thanks Mike
Old 08-13-12, 08:31 AM
FutureSC
FutureSC's Avatar
Well essentially you take the output speaker wires from the nak, cut them, and then run speaker wire all the way back to the trunk where you cut the output speaker wires from the amp and plumb your new speaker wire into those. It generally talks about that onion the writeup but some of the wiring may be a little different based on you not having the pioneer system.
ArmyofOne
04-26-19 04:41 AM
Pepp
03-05-19 11:48 AM
teins4me
02-25-09 09:15 AM
kmn5
06-02-04 07:07 PM
Quick Reply: can someone direct me to thread for bypassing factory amp
