SC- 1st Gen (1992-2000)
Passenger window problem? HELP?
Old 06-19-12, 03:45 PM
rogers2014
rogers2014's Avatar
Default Passenger window problem? HELP?
Ok guys so basically i don't know if the regulator needs lubrication or it may seem like it's dying...lets start off with the driver side, moves up and down as it should one day i did the auto window and it went all the way down. Next time i did it on the driver side window it went down half way and clicked tried to pull it back up didn't work. Then my cousin Josh shut the car off (car was in acc mode) and put it back on, window went up with ease....but the PASSENGER SIDE has had a problem since i got the car. Moves really slow, i mean REALLY SLOW as in slower than a turtle....NOW YOU KNOW THATS SLOW LOL any suggestions? i never pulled the pass window all the way down cuz scared it might get stuck but is the motor dying? or should i just lubricate it? any suggestions would be greatly appreciated!
Thanks,
Chris
Old 06-19-12, 03:51 PM
cmh
cmh's Avatar
my car does the same thing but when u lower it from the passenger side switch it goes down and up normal... does ur car do the same or is it slow from passenger and driver switch?
lets see who has an answer for this. im sure its the motor
Old 06-19-12, 04:00 PM
rogers2014
rogers2014's Avatar
Hey it's slow from the passenger side for the passenger window, and i believe it is slow from the drivers side switch as well, i will confirm it in a few days as the car is being stored. Ok so are you still having the same problem? is it the switch or actual regulator?
Old 06-19-12, 04:02 PM
rogers2014
rogers2014's Avatar
I'm thinking it is the motor, and if thats the case SMH!!! Cause here in Toronto parts for these cars are hard to find, and when you do some people (not all) charge rape!
Old 06-19-12, 05:31 PM
rogers2014
rogers2014's Avatar
anyone else car to help? input please!!
Old 06-21-12, 08:25 AM
SC400slide
In Recovery Mode
SC400slide's Avatar
look for stuff caught or in the way inside the door,
Mainly check the rubber on the outside, because the window get's stuck on that, and also on the outside a little rubber button looking thing, that was part of my problem last time...
geopig
ES - 5th Gen (2007-2012)
03-25-19 04:17 AM
TTschmitta
02-06-13 11:07 PM
rprofitt
GX - 1st Gen (2003-2009)
11-16-07 03:29 AM
dpakman91
08-28-02 01:41 AM
Quick Reply: Passenger window problem? HELP?
