The I wrecked my 1JZ 95 SC300 and swapped it into a 94SC400 thread
#31
is it one of those omni power map sensors you see on ebay?
you definitely need to find either a stock 1jz or 2jz map sensor, the 4bar will not scale correctly with the factory ecu. However i dont think it would keep it from starting and atleast idling
are you using the stockinjectors? and are you sure the fuel is actually getting into the cylinder?
also pull a coil and plug and ground it to something on the engine and have someone crank the car, you should see the plug firing
#34
It definately doesn't run when its disconnected, you may get it to fire up briefly with no map installed.
I know with the 3 bar or a 3.5 bar map sensor it would start up and very quickly fall on its face and stall out.
car starts and runs just fine with a 2jz map sensor though.
93MSB
Performance & Maintenance
27
02-16-20 08:17 PM
