Wow it's so clean, I just got a 92 green pearl sc3, this does look lighter though? Either way this is inspiring! What coils are you on? I can't zoom in enough to see but what size tires are you running?
Account2x: that antenna is so much cleaner then the MDX one. Please share what it is and were you got it!
You'll need the antenna mount of a late model Celica.
Celica locking nut. The antenna pictured above is from Honda Element or Insight, antenna pictured below is from a S2000 antenna. Element/Insight antennas are a more streamlined form of the S2000 antenna.
This piece needs to be switched over from the SC antenna.
Not pictured but the top plastic beneath the locking nut must also be reused of an SC and trimmed slightly to fit.
Celica bracket must be bent to fit.
I know this may sound complicated but once you physically inspect both the new and old antennas along it becomes fairly apparent.
