SC- 1st Gen (1992-2000)
Trunk release won't work
Old 07-09-12, 08:39 PM
SC400slide
In Recovery Mode
SC400slide's Avatar
Default Trunk release won't work
Hi again
How would I go about fixing the trunk release switch interior button.
I know that it might be locked, but I have no valet key. Just re-made ones.
Does anybody know how to jerry rig it or something?
Old 07-09-12, 08:40 PM
ItsMiles
ItsMiles's Avatar
im running into the same problem... not so much of an inconvience since you can still open it with the key from outside... but i mean would be nice to just be able to pop it
Old 07-09-12, 10:01 PM
chingpo05
chingpo05's Avatar
pull off the panel and the plug should be a two wire plug. jump it with a wire and itll open. if you want to rig a button then you will need one that has a spring-ed toggle switch so that it will throw the switch back into neutral position
Old 07-10-12, 07:34 AM
SC400slide
In Recovery Mode
SC400slide's Avatar
Thank You.
How do I jump the wire? stick them together?
Old 07-10-12, 09:10 AM
charley240
charley240's Avatar
The trunk release has two plugs. Top plug closest to the instrument cluster is a blue and something wire, but the bottom plug closest to the brake pedal is a green and i believe red wire. The green and red wires need to be connected together.
You should search it, there are 2 detailed writeups on this with pictures of what jumpering wires together.
Goodluck
Charley
Old 07-10-12, 01:04 PM
Hawaiian82
Hawaiian82's Avatar
Charley is correct, that's how I tested mine cause mine wasn't working either
Old 07-10-12, 03:35 PM
SC400slide
In Recovery Mode
SC400slide's Avatar
How do I get the button OUT?
I just tried, and it cracked a little.
Old 07-10-12, 05:33 PM
charley240
charley240's Avatar
I dont want to be a jerk, but youre now in 2012, where anything and just about everything is on the net. And being in a specifically catered car market that has such an awesome search feature , you should try it out, i promise it won't bite.
Charley
Old 07-10-12, 06:53 PM
N1T3MARE
N1T3MARE's Avatar
Check your fuse also. It is possible for it to be blown.
Old 07-11-12, 07:46 AM
SC400slide
In Recovery Mode
SC400slide's Avatar
I checked the "door" fuse. it looked almost corroded inside but it wasn't broken in 2. The gas cap lever works anyway.
Old 07-11-12, 10:36 AM
MNSC3
MNSC3's Avatar
I have the same problem, trunk release just stopped working one day, gas door release still works, I can open the trunk with the key
Old 07-12-12, 07:35 AM
SC400slide
In Recovery Mode
SC400slide's Avatar
Charley
I searched almost everywhere and I count find it.
Would anybody else know how to dod this.
Old 07-12-12, 09:55 AM
MNSC3
MNSC3's Avatar
update, mine was LOCKED, must have hit the button with my knee ? trunk latch works fine
Old 07-12-12, 10:06 AM
charley240
charley240's Avatar
Im on my phone right now, but the title of one of the threads is called 'RePlacement nubs for center armrest'
Type that in the search and search as a title
Charley
Old 07-12-12, 02:48 PM
SC400slide
In Recovery Mode
SC400slide's Avatar
Charley
Thank you Charley!
I will try this today.
For easier access in the future (who would have guessed were it was!)
https://www.clublexus.com/forums/sc-...r-armrest.html
Quick Reply: Trunk release won't work
