electrical issue
my problem::: the whole drive side power windows switch, memory seat, doesn't work... i had to ghetto rigg it, by using a power source from my door light for constant power
my cigarette lighter doesn't work neither check all my fuse's, everywhere, i traced every wire for damage.. took my whole center console apart, gauge cluster , to see there wires back there and NOTHING, everything looks ok... again all fuses where check. i just don't know where to go at this point
alright im currently working on my car. i said **** it, today im going to be a electrician lol with my multi-meter and test light out .. i fixed the cigarette lighter.. for future reference...... the rear of the cigarette light itself has a fuse aside from the harness.. i think its called inline fuse.. its a gray L shaped hard line which is a fuse in the middle of it has a 10mm nut on it (again) right behind the lighter (power source) itself. its not going to look burnt, you have to get a test light, and see if there's power going from and too the L shaped fuse bridge on the rear of lighter..i bridge the connection and got power.. i need to solder it .. no pics sorry..
NOW on to the windows switches... currently testing the harness.. will keep you guys updated..
