yellow airbag harness relocation? and splash guards..
can someone post a pic of where they relocated the yellow wire? if i disconnect it will it extend a little bit or no?
and one more question, i just got my fenders rolled and i dont think the splash guards are going to go back on...are they necessary to put on? i live in the bay area so there is no snow, only rain... thanks
All you need to do is cut the ziptie on the inside kick panel holding the harness under the dash and pull as much of the excess wire out the grommet as you can. Then disconnect the battery and unplug the connection at the sensor by the front of the fender. Once that is done take the harness and re-route it through the fender brace and ziptie it as far as you can to the top of the fender, you'll also need to try to put the hood release cable as high up as possible. Splash guards are not needed.
Studiogeek
Performance & Maintenance
05-20-14 07:13 PM
Touge
SC- 1st Gen (1992-2000)
02-21-08 02:37 PM
