Sunroof Question
Really should not be too bad. I have 2 whole sunroof assembly in my garage, I am happy to take any pictures if you need them. One I took apart and the other is still 100% complete. I can't remember exactly how the glass comes out, but I do remember it being pretty easy.
Let me know.,
Thanks,
Rick
Let me know.,
Thanks,
Rick
to pull the entire assembly out you have to pull both front a-pillar trim pieces off, as well as the rear seat and all the rear trim pieces. Then you have to get the headliner out. Unplug the wiring harness and make sure to remove the drain lines carefully from each corner. From there there are around 12-14 bolts that hold the assembly in, and its best to have someone there to help, its a bit heavy especially in that tight of a space
