Should the trunk open with the key?
I cant seem to get my key to open the trunk. I have to open it from the inside. Is there some trick to it, or does it only open at certain times (like if doors are unlocked, or etc.)?
keys
There are different keys made for our vehicles. You may be using the valet key, which I believe does not allow access into the trunk and glove compartment for security reasons.
Tim
Tim
that happend to me once and it wasnt frozen i just tried it the next day and it worked but for some reason my glove box doesnt lock. and i am using the correct key it hoes in but will not turn and im afraid to go to a delaership for something relatively minor
There might be some pressure on the latch that you can't overcome by turning the key. Try pressing further down on the trunk lid while turning the key.
Tried pressing down on the trunk and that didnt work. I took the cloth cover off and nothing jumps out as being wrong. When I put the key in, it turns like a centimeter, but I can feel the little rod turning with it...so....
One more question....my key only goes in the lock halfway, is that normal or should the key go fully into the lock?
Maybe you can try to lube the key and/or hole. Sounds like the link between the door lock and lock cylinder is either bent or needs a bit of light grease. The graphite is a lubricant for the key and inner workings of the lock. I use the graphite powder from Home Depot when my Lexus dealer messed my trunk key hole. It works well if your key doesn't go into smoothly. or you can try other product like Tri-Flo.
There is a hood lock under the steering wheel that when pressed locks the hood and I think (but not sure) that it locks the trunk too.
Can you open your hood? If not this is why.
There are two keys that came with your car.
1 - valet key - starts engine and opens front doors only
2 - master key - opens everything the valet key does, in addition to:
2a - unlocking the above-mentioned lock to enable the hood, gas door, and trunk
2b - locks and unlocks the glove compartment
2c - opens the trunk
If your key can lock and unlock the glove compartment, you are using the master. If you are able to put that same key all the way into the trunk keyhole, but unable to turn it, they probably replaced that lock cylinder and didn't give you the key.
Well I tried graphite and that didnt work I dont think.
I mean the remote unlock works fine for opening the trunk. Doesnt the lock, unlock mechanism that unlocks it when you press the button under the dash the same mechanism that should unlocks it with the key?
