STOCK 1JZ 906rwhp
What type of dyno and are the numbers corrected? All the 2j's and 1j's make gobs of power in stock form but not for long. Congrats on the numbers and hope to see some track times soon.
hello all i just joined after seeing this discussion about my r33 thought i could answer some of the questions on it
Stock 1jz with stock head and stock cams.
oem gaskets and oem head gasket
71mm bw t4 125 rear housing large turbine wheel.
125 zex shot.
36psi
q-16
Microtech lt16
dual feed rail -8 feed lines (2) -6 return
I.D 750 injectors rail preasure 65psi
3.5 diff ratio
also r154 tranny
OS giken triple plate clutch
os giken push pull reverse kit
Total of 4 runs over 900hp and 4 over 800hp.
125 zex shot.
36psi
q-16
Microtech lt16
3.5 diff ratio
also r154 tranny
the numbers are uncorrected it was done on a dyno jet
so far motors done 30+ pulls and still running like new
just had to get cage and other safety items in check before i could race but took to long and missed out on the season here in canada will be coming out at the beginning of next year with more track testing and increasing boost and spray through out the learning curve
i know what you mean im working on a mkiv 2j with my dad to build a full interior sunday 1400+ fun car for him just started it tonight actually going to do video of build and progress on both cars over winter in our shop
and good luck to your friends 2 jz
seanf
125 zex shot.
36psi
q-16
Microtech lt16
3.5 diff ratio
also r154 tranny
125 zex shot.
36psi
q-16
Microtech lt16
3.5 diff ratio
also r154 tranny
Awesome. Please post tons of pics
http://s1264.beta.photobucket.com/us...143-1.jpg.html
http://s1264.beta.photobucket.com/us...ml?sort=3&o=20
http://s1264.beta.photobucket.com/us...ml?sort=3&o=16
http://s1264.beta.photobucket.com/us...ml?sort=3&o=11
sorry cant figure how to put thumb nails up
This is the most alarming part of your set up! 750cc injectors that make 900rwhp. This seems to be impossible or merely a ticking timebomb waiting to go off. The concern isn't if it made it more so that it made those numbers im multiple runs..
Also, ID doesn't make 750cc Injectors, are you sure?
They only make 725cc, 850cc, 1000cc, and 2000cc injectors
seanf
