SC- 1st Gen (1992-2000)
My 1j Swap
Old 08-13-12, 12:57 PM
98Sc3001jz
98Sc3001jz's Avatar
ok heres the stock PS cooling line and the new PS fluid cooler. this is what im currently working on bc its kind of a pain in my a$$. went to napa and got 10 feet of high pressure PS lines so i can mount and relocate the cooler.
Old 08-13-12, 01:07 PM
98Sc3001jz
98Sc3001jz's Avatar
The first 4 pics are the IC piping and the brackets that i had to make for the top IC mounts. The last pic is the tranny tub and how im cutting it so that the shifter will fit. its not that the shifter is in the wrong spot its that the stock extension on th tranny hits the tub so.
Attached Thumbnails My 1j Swap-dscn0019.jpg   My 1j Swap-dscn0021.jpg   My 1j Swap-dscn0025.jpg   My 1j Swap-dscn0026.jpg   My 1j Swap-dscn0028.jpg
Old 08-13-12, 07:44 PM
Vrank
Vrank's Avatar
the sides will get tight too where the tripod comes out to the shifter base. mk4 trans tunnel for auto to manual swaps is super proper
Old 08-14-12, 03:34 PM
megamax
megamax's Avatar
Sweet. What are u going to do about ur exhaust?
Old 08-14-12, 05:56 PM
98Sc3001jz
98Sc3001jz's Avatar
i ordered a new y pipe and mid pipe thats 3 inch and i also have a 3 inch cat back but its for a MKIII supra so im gonna have to modify the hangers and i might have to mod the piping but i dont think i will
Attached Thumbnails My 1j Swap-103_0174.jpg   My 1j Swap-103_0173.jpg   My 1j Swap-103_0172.jpg
Old 08-15-12, 01:42 PM
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
Man, its getting there... We need videos of the start up and so on.... lol
Old 08-15-12, 04:39 PM
jaysus101
jaysus101's Avatar
looking good!
Old 08-15-12, 07:40 PM
98Sc3001jz
98Sc3001jz's Avatar
Ok as it sits right now i am gonna have to mod the exhaust bc i went to mock it up and the midpipe hits on the undercarriage but i might just take a torch to it and bend it back a little. im also trying to fig out where i wanna mount the PS Cooler. all in all i should have it at least running this weekend but cant drive bc i have no driveshaft
Old 08-17-12, 12:42 PM
98Sc3001jz
98Sc3001jz's Avatar
ok im gonna post this on here bc i cant post in the classifieds. i dont really have the money for a custom driveshaft so im gonna go the cheap route for right now, I NEED THE FRONT DRIVESHAFT OF THE R154 FROM A SUPRA!!!!! if n e one has one or knows someone who has one plz let me know
Old 08-17-12, 09:53 PM
joe diego
joe diego's Avatar
You gotta farmers tan on your left foot. I wanna see your right foot.
Old 08-18-12, 01:39 AM
98Sc3001jz
98Sc3001jz's Avatar
lmao well there both the same. to much time outside with flip flops
Old 08-18-12, 04:45 PM
projectm
projectm's Avatar
I like shiny pipes.
Old 11-04-12, 03:22 PM
98Sc3001jz
98Sc3001jz's Avatar
Default Update!!!
Ok so i have the engine and tranny in, the wiring harness has been extended and hooked up, the new 3 inch aluminum driveshaft from driftmotion, intercooler and intake are done.
********NOW THE PROBLEMS IM HAVING********
1.) The fuel line is spraying fuel everywhere. Ive called around and can not find the copper banjo washers that go on that line. If anyone knows where i can get one i would greatly appreciate it.
2.) First know that the key is not in the ignition at all, its on the floor. When i connect the battery cables up the engine starts turning over by itself. Now i dont know if its possiable that the starter is stuck open and as soon as power hits it it turns over. I figure that im either gonna change the starter out for a new one and cut the lead wire for the starter and run a pucs button ignition. Any thoughts on what i should would be very helpfull.
Old 11-05-12, 07:46 AM
StiCk3
StiCk3's Avatar
1) if you bring your old copper washers or the actual banjo bolt any auto parts store can match them up for you.
2) sounds just like the starter problem i was having after installing my 1JZ. Check out the thread in my sig to see if that solves your problem.
Old 11-05-12, 10:01 AM
98Sc3001jz
98Sc3001jz's Avatar
well i somehow lost the old copper washers but i took the fuel bolt to advanced and found some washers that might work but i'm gonna get the starter fixed first so that way i don't have an uncontrollable car
Quick Reply: My 1j Swap
