95 sc300 cluster in 92 sc400 dead rpm... need help!!!!!
iv searched a lot on fixing clusters witch few people do them selfs...I installed a cluster from a 95 sc300 in my 92 sc400 all needles light up but the rpm does not move. I've read that it should work but the rpms will be off a bit...I don't mind that.. what can it be? I have my stock sc400 cluster I can use for parts, can I fix? Are the parts interchangeable? I noticed there different ...please help!
1JZ Single SC400
If my memory serves me correctly, i dont think you can swap that year into a 92, only 92-94. That maybe your problem. Also is the cluster you swapped in a manual or auto 300?
thegadget
Performance & Maintenance
12-23-07 10:46 PM
