i need help!
I have a 1995 SC300.
this is what i need help with.
i have a faulty alarm so it goes off every so often its retarded ill drive it come home and out of nowhere itll go off like 45 minutes after i parked it. i run out to turn it off. one day i was pissed so i let it go off and it apperantly shuts off after a while. thats the scenerio, turns on and then off by itself.
i want to disable the alarm. temporary fix i disconnected the horn. anyone know of a fuse or a wire i can cut to disable the alarm? or know of a way to fix this??
I had the same thing happen to my alarm. If you lock the doors by pressing the button the door and then close it, the car will be locked but the alarm won't be activated.
I eventually put in an aftermarket alarm and my installer disabled the factory one. I'm not sure how he did it though.
WTFUDGE! how many sirens do we have!? i disconnect one by the top of the radiator, another on the bottom by the lower engine splash guard but theres another which keeps going off. WTFUDGE lmao anyone know the location of the other/s??
