How to remove Glovebox?
Hey guys,
I want to install my DVD player in the glovebox but to run the wiring I need to remove the glovebox pocket. Any insight on how to remove the glovebox (hidden screws, etc) would be appreciated.
Thanks,
Ali
Thanks,
Ali
I've done it before,...can't remember right off hand at my desk, but I know there are few in the top (screws) and I believe 2 are covered with lil plastic tabs. It's pretty easy,...just take everything out of the glove box and feel around or look with a flash light for plastic covers.
I did it a while ago to fix my a/c but didn't fix it costed me a bunch for lexus to fix... ok, you start at the bottom, remove the bottom panel where your feet are, it is just clipped in the front and you will see 3 or 4 of those black clips that hold it up, I don't really know how to describe, if you still can't do it let me know I will post diagrams. Then you have 4 screws, two at the bottom, two under those black squares in the glove box at the top... take those out, there are then I think a hidden clip in the center top of the glove box, I know the description isn't that bad, but maybe that will give you some guideline. Then just pull the thing out.
