Handbrake Problems
Handbrake Problems
Hey guys,
I'm new to this forum and I have a 1992 SC400. Can anyone tell me how to fix my handbrake? It's completely disconnected, however, when i pull it, the "brake" light comes up. I'm not sure if this is relevant or not, but when i'm hitting a sharp turn going relatively fast or when i gun it from a stop the "brake" light comes on again. Any help appreciated, i'm not that great with cars, but hey i'm just starting out.
I cannot help you with the handbrake issue as that is one area of this car I have yet to delve into, however regarding the brake light coming on while in motion - check your brake resevoir. The light comes on to let you know the fluid level is getting low. It would also be a good idea to check your brake pads & rotors, as when the pads begin to wear down significantly you will see some decrease in fluid level. Checking the rotor wear is just a good idea since you'll be down there anyway & it will let you know if they need to be turned or replaced when you replace your pads.
I believe the brake light comes on to let you know your ebrake is on. There is a switch located on the ebrake base. The brake light comes on while turning a corner probably because your ebrake is disassembled, so whilee turning, your ebrake handle is moving on closing the circuit for the ebrake light
Thanks guys, ill definitely check out the rotors and pads etc as well as the fluid levels. however.. any one know how to re assemble the handbrake? its really been bothering me cause i love using it haha
