Running an OEM LS460 wheel . . .
http://www.ebay.com/itm/Factory-Lexu...1cb198&vxp=mtr
Finally found a decent looking OEM wheel and figured I could pick a set up for cheap. Only problem is the 5x120 bolt pattern.
Any thoughts on running an adapter? How much would the adapters set me back? Wheels are 32mm offset, I think stock offset is 50mm.
your in luck
you dont need an adapter
5 x 120 will fit on your car no problem, the only thing u need s 'wobble bolts'
which can also be bought on e bay for about 50 bucks
then just make sure the bore is the same, 60.1 mm, if not u need hubcentric rings which are also cheap and also on e bay.
good luck
good luck
