Need Help running wires to a pillar gauges
Like the title says, I need to know the best way to run wires to my gauges on my a pillar pod.
I have the wires coming through the fender firewall and I want to get it up to the A-pillar. How do I do this?
pull off the A piller there should be some holes behind it. remove the O #@$% handle. to get the wires there the holes us a long piece of hard wire. coat hanger or lacing wire. push that threw until u get tothe underside of the dash. from there look for a hole in the firewall or make one. there should be afew in that area. most will have a plug or a plate that u need to remove. use the hard wire to run the wires threw all the holes you use. make sure the wire is long enough to see both ends.then tape your wiring to the hanger. pull threw. make sure you cover the edges of the metal with a grommet so you dont short your wires. good luck. hope that helped
Yea is does. I am going to have to do it a slight bit differently though. I have no choice but to feed the wires up the dash to the A-Pillar. I thought there might be an easier way though. ITs a tight fit.
