SC- 1st Gen (1992-2000)
Instrument Cluster Bulbs
Old 09-26-12, 03:24 AM
Bankswood
Bankswood's Avatar
Default Instrument Cluster Bulbs
I need to replace the bulbs in my cluster and have done the research on removing the cluster but can't find the info on what type and how many bulbs I need.
Can someone tell me the type and size bulb? Also is LED a better way to go?
Old 09-26-12, 04:14 AM
mrpeterman
mrpeterman's Avatar
Here is the DIY I followed: https://www.clublexus.com/forums/es3...ing-bulbs.html
Old 09-26-12, 05:57 AM
sr71b
sr71b's Avatar
#74, the leds will give you hot spots where the light shines, in order to get an even look you have to do the led light strips, i replaced mine with the standard bulbs since i wasn't converting all my lights to leds just yet.
Old 09-26-12, 07:06 AM
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
Size 94, they are eight them. They are in black and twist and pull out.
First time I saw that write up, very informative and great effort!
Old 10-01-12, 04:25 AM
Bankswood
Bankswood's Avatar
#74 or #94 ? Just ordered #74
Old 10-01-12, 07:53 AM
sr71b
sr71b's Avatar
you are fine with the #74
Old 10-01-12, 11:34 AM
O. L. T.
Keeper of the light
O. L. T.'s Avatar
74 are useless and 94 are incorrect, but since I have spent ten years on here telling everyone the proper bulbs to use and nobody searches I've decided to stop. Good luck. If you're using 74's you'll need it.
PS- the ES cluster is designed differently, using their LED write ups for the SC will get you a pretty horrible looking cluster. Their spreader is MUCH more efficient and light screams through it whereas the SC has over 8 walls inside on each side.
Old 10-01-12, 12:41 PM
Bankswood
Bankswood's Avatar
O.L.T. it's not that I'm lazy I will do as much research as anyone . I love to learn about stuff. I was able to pull up your FAQ on the bulbs. I thought maybe another member had found a newer solution that was not Lexus oem.
Please understand that when I ask a question on this or any forum I try to gather as much info and hopefully answers before posing the question.
I'm new to the SC world and I'm really going to need support from this forum to get my new baby up to my standards.
Can you explain why the #74 bulbs aren't going to work?
Old 10-01-12, 01:23 PM
sr71b
sr71b's Avatar
i used the #74 in my cluster and its fine
Old 10-01-12, 04:01 PM
Bankswood
Bankswood's Avatar
Thanks. What do you think about LEDs in the cluster?
Old 10-01-12, 04:23 PM
O. L. T.
Keeper of the light
O. L. T.'s Avatar
Originally Posted by Bankswood
O.L.T.
I wasn't actually directing that to you, but you could have found that in a quick search, it's EEEVVEERRYYYWHERE.
The 74 are dim, undersized, and WRONG. Anyone who likes using 74's haven't seen what the proper bulbs look like in there. Look in the ice blue thread, even though it's in a million spots you'll find it there.
Deegee
Performance & Maintenance
08-10-16 02:26 PM
iwannadie
04-09-13 07:31 PM
hfsdude007
20
02-04-13 02:32 PM
evilninja
12-17-10 11:07 PM
lcc014
08-14-09 01:10 PM
Quick Reply: Instrument Cluster Bulbs
