1jzgte swap (Proefi Friendly)
No it is not a Lexus. Sorry to say. I figured Id post it up here in the SC section because most of you swap 1jz and 2jzgte in.
It is a 1991 supra with a 1JZ on Proefi 128. With all the bells and whistles.
So if anyone needs any help with Proefi, I may be able to help, I built my own harness and have done all the work by myself and help from friends in the community.
Here is the Build spec:
1JZGTE:
Drewgo manifold
Drewgo Downpipe
T70 turbo
4'' exhuast
4" Muffler
4" Inlet
4" K&N filter
3'' aluminum charge Piping
24x12x3 FFIC
Tial Q BOV
COOLING:
Koyo oem radiator
Upper aluminum Coolant hose
2x 35mm couplers
2JZgte Fan clutch setup
2jzgte USDM waterpump
HEAD:
1ZZ coils
1ZZ coil brackets
BC 272 cams
BC springs retainers
HKS cam gears
HKS timing belt
Clear Timing cover
FUEL:
Precision 1200cc Injectors
Driftmotion Top feed rail
Dual Bosch 044 pump
10micron Inline bronze Filter
38' of PTFE fuel line
check valve
Flex fuel
ECU:
Proefi 128 ECU
Flex fuel E85
52mm CAN Gauge
Map sensor
Fuel sensor
Radiator Pressure
Exhuast Back Pressure
Oil Pressure
Flex fuel sensor
Wideband sensor
Traction Control
INTERIOR:
HKS Turbo timer
1GG tach
Gauge Pod pillar
TRD shift ****
Shifter and E-brake Boots
Sparco Sprint Seats
MKIII Wedge engineering Brackets
3'' 5-point harness
Suspension/Drivetrain:
R154 conversion
1-piece Aluminum Driveshaft
JZ bellhousing
JZ Flywheel
ACT XT Pressure plate
ACT 4-puck disc
ACT throw-out Bearing
SS Clutch line
Varrestones Wheels
18x10.5+30 Rear (295/40)
18x9.5 +30 front (255/40)
Tein Mono FLEX with EDFC coilovers
3.91 Rear end rebuilt Shimmed (2-Way)
Marlin crawler Thrust washer.
Poly Tranny mounts
Solid Motor mounts
Front Poly Bushings
Rear poly bushings
Brembo BBK 14.2'' Fronts
Brembo BBK 13.8'' Rears
F/R ST sway bars
F/R Stop tech pads
Shine S2 Front Lip
Shine S2 Air guide
Coatings:
Powder coat Valve covers
Ceramic coat Manifod
ceramic coat scroll
ceramic coat DP
ceramic coat wastegate
Polish Coolant
Polish upper coolant
Polish turbo
Polish Inlet
Polish Plenum
Polish Charge piping
MISC:
P/S SS line
Beech P/S ALum overflow
Beech Coolant overflow
Ill start Uploading Pictures!
1JZGTE:
Drewgo manifold
Drewgo Downpipe
T70 turbo
4'' exhuast
4" Muffler
4" Inlet
4" K&N filter
24x12x3 FFIC
Tial Q BOV
COOLING:
Koyo oem radiator
2x 35mm couplers
HEAD:
1ZZ coils
1ZZ coil brackets
BC 272 cams
HKS cam gears
HKS timing belt
Clear Timing cover
FUEL:
Dual Bosch 044 pump
check valve
Flex fuel
ECU:
Proefi 128 ECU
Flex fuel E85
52mm CAN Gauge
Map sensor
Fuel sensor
Radiator Pressure
Oil Pressure
Flex fuel sensor
Wideband sensor
Traction Control
INTERIOR:
HKS Turbo timer
1GG tach
Gauge Pod pillar
TRD shift ****
Sparco Sprint Seats
3'' 5-point harness
R154 conversion
JZ bellhousing
JZ Flywheel
ACT 4-puck disc
SS Clutch line
Varrestones Wheels
Poly Tranny mounts
Solid Motor mounts
Front Poly Bushings
Rear poly bushings
F/R ST sway bars
F/R Stop tech pads
Shine S2 Front Lip
Shine S2 Air guide
Coatings:
ceramic coat scroll
ceramic coat DP
Polish Coolant
Polish turbo
Polish Inlet
Polish Plenum
MISC:
P/S SS line
