Power tilt wheel problem.
I know this happens fairly often... my dad's 93 sc300's auto tilting steering wheel will go only one way and tries to come back down and gets jammed up. is there an easy fix to this or to we need to go through the dealer for a 500 dollar fix up? thanks.
Guest
Posts: n/a
I'm not sure about the exact fix, but mine does the same rarely.
There was a post a while back about re-greasing the steering tilt gears. Here is the post -
https://www.clublexus.com/forums/sho...=tilt+steering
Next time you can use the search function to see if anything has been posted previously to answer your current question.
