SC400 Audio Install
Nice setup!
This gives my inspiration to finish my custom subwoofer bracket. I cutout the stock nakimichi out of the stock subwoofer bracket. I was planning on putting a pioneer free air subwoofer in it but the magnet was too large.
What is the specific model sub your are running? I googled it real quick and it says that it can run in free air.
Any shaking or rattles with the free air sub there?
Didn't separate the plastic from the metal. I used a cutoff wheel to shave down the metal housing so the sub would fit under the factory grill. Afterwards I used camper shell tape to seal for air leaks around the sub.
If you want to re-use your stock speaker enclosures I did a write up on how to do it on this thread.
https://www.clublexus.com/forums/5564109-post6.html
Gives you a nice enclosure for your front speakers.
Looks real nice, great that it doesn't take up any more space then a stock set up other then the amp of course, but you probably got rid of the old amp/cd changer so you probably even have more space then before. Looks real good, in fact I think I'm going to do the same thing. That amp is hooked to all your speakers and the sub as well?
-Lexstacy-
07-14-04 06:15 PM
scfreak
04-30-02 12:22 PM
