SC- 1st Gen (1992-2000)
Help me the back of my car is drifting
Old 10-16-12, 12:44 PM
LEXXIUM
LEXXIUM's Avatar
Don't pull your e brake at high speeds while turning
Old 10-16-12, 11:05 PM
1uzSC
1uzSC's Avatar
Cant handle the power.
Old 10-17-12, 06:56 AM
sc400ka
sc400ka's Avatar
POWA OVA!!! anyway i would make sure to get this checked out if it snows in your area. because driving in the snow with a loose *** end is no FUN! unless your in a parking lot!
Old 10-17-12, 10:09 AM
bpgt
bpgt's Avatar
There's only one real answer to the original poster's inquiry...
I'm Rick James, b*tch!
In all seriousness, and like many others have suggested, conduct a 'once-over' of your tires and suspension, and replace any worn suspension parts. You definitely don't want to pose as a safety hazard for yourself or anyone else on the road.
Old 10-17-12, 11:24 AM
ArodDaLob
ArodDaLob's Avatar
you're countering too late.
Old 10-18-12, 12:21 AM
KahnBB6
KahnBB6's Avatar
Received 1,237 Likes on 864 Posts
Originally Posted by ckja
When am turning the back of my car is swinging why
As many have stated, check and/or replace your rear lower control arms, replace the sway bar bushings and possibly the end links. Be sure the condition of your shocks. Then, an alignment. These cars are getting old. My front lower control arms were causing me to shift around unpredictably on the highway in turns and I replaced them. Rears can do the same thing.
If you are driving with an LSD (2-way clutch especially but even with a Torsen) you may have a slight tendency to be tail happy. If this doesn't describe your car then disregard.
There is a proven alignment setup called a "Lance Alignment" for Supra TT's that helped reduce my car's tendency for tail-happy oversteer. It helps to have the suspension set up more like a TT but it's mostly applicable to SC's.
alexkidd
07-18-17 06:21 AM
Dtaylor3
Suspension and Brakes
12-29-14 04:13 PM
RamAirRckt
05-29-12 03:28 PM
SCWB
13
12-12-11 05:43 PM
tiger4life
12-21-10 11:49 AM
Quick Reply: Help me the back of my car is drifting
