Thought i would share a pic!
10-22-12, 04:34 AM
I used an SC400 p/s reservoir.
So you wanna run the factory feed line?
The factory belt should work iirc.
10-22-12, 05:31 AM
10-22-12, 06:42 AM
Yup I'm gonna run basically factory fuel system for the time being just upgraded pump
10-22-12, 07:16 AM
Ok then why change the rail , if you wanna run stock stuff? i would leave everything stock and remove the Fuel bypass dampner on the side of the block .
10-22-12, 11:09 AM
Only reason I was gonna run rail because I already had it. But I guess I could lay it to the side and run factory rail, should I delete charcoal can too?
10-22-12, 11:33 AM
Just run the stock rail till you replace you lines first.
Yes you can remove the charcoal canister.
10-22-12, 11:41 AM
Thanks for the info man. That's been causing me not to sleep haha you think a single 340 pump will be ok for right now or should I try for two?
10-22-12, 11:42 AM
Also I shouldn't use the aftermarket fpr? With factory fuel rail?
10-22-12, 12:16 PM
340 flows more than Walbro and i made 500 on single walbro so that tells you right there.
I used the stock regulator , stock lines feed and return, it even had the dampner one the side of the block.
There is alot way of doing things lol call me when you get a chance i can explain it to you better!
10-22-12, 01:25 PM
Very nice. How do you keep your garage so clean?
ScBouncE
Build Threads
84
04-08-22 12:01 AM
kyddo112
01-16-20 05:31 AM
silver470
Performance & Maintenance
09-12-15 07:19 PM
dsouthmia0
Build Threads
04-27-15 05:25 PM
619Rider
42
11-02-11 08:21 PM
05 ,
1jz ,
2jz ,
aem ,
coils ,
ferrea ,
gate ,
gx470 ,
is300 ,
keepers ,
lexus ,
lq9 ,
mojo ,
performance ,
solenoid ,
valve
