puddle light mod /clear side marker help
So am thinking about doing this to make my sc look cool and make my car stand out. My major concern is the wiring part. What should i tap into for the power source?or should i get an independent switch. Also i would like to do clear side markers for a different look but i can't seem to find the material anywhere. No luck at home depot, the mod looks very easy... just trace, cut, and seal the light
It'd be better if you have an independent switch for it. Raine, actually did the entire wiring with independent switches and even went as far as a secondary fuse box for all the accessories. As for the clear sidemarkers you have the option to buy the Vertex clear ones.
thanks fellas
will be attempting the clear sidemarkers mod very soon will post pics when it is done
Here's how Raine's puddle lights, it's towards the bottom
https://www.clublexus.com/forums/sc-...ngoing-14.html
And as for the wiring on page 8 he talks about how he rewired his whole car and used an auxiliary battery in the trunk. It's a bit overkill for just puddle lights but the idea is out there in case you wanted to add more lights later.
GL w/ the lights!
GL w/ the lights!
