who's slammed on 20's with coilovers not bags
im thinking about buying some deep dish 20's but want to know what the clearance would be on the sc and if i would have to do any fender modifications. not sure what if size 20's i want yet i just know i want a nasty (big) lip on it. i see people putting 19's all the time on the sc but i just want to take it up a notch. just want to see some pics of sc wheel and tire combinations with 20's
If you want to really slam it it will be rubbing against the plastic fender trim on the front wheels and you definitely want to relocate the wiring harness on the front driver side wheel well.
If you're set on 20's make sure you budget in a body kit and a paint job with it; 19's look big on a stock body SC (especially pre-97) unless you pull it of right, and 20's just look Dub City High Roller on a stock body.
Also depends on the disc face. High Disc with the right offset will give the illusion of nasty lips. You wanna be legit...go with low offsets n make the car fit the wheels. You wanna cheat it im sure xxr makes a wheel you can give the illusion.
I see in your avatar that you have a 95-96, your car on 20"s might look a little like this
Personally I'd save the 20"s for a luxury sedan, but like others said, body kit or even 97+ 20"s can look good
Im running 275 in the rear and 245 in the front... I can sit the front a bit lower but im going to be running a kit so im going to wait. My front lip already has touched the floor on speed bumps and such. Actually looks better in person. Im going a little tighter on the fitment tho. About 10mm more on front and 10mm on the rear. Sofar no tire wear from rubbing or damage.
