Car runs cold ( AT NIGHT) should i be worried?
I live in Arizona so the heat can be pretty unforgiving; so i only run a water additive (something similar to water wetter) and distilled water.
during the day my temperature gauge stays just a bit below half (which is great).
but ever since ive purchased and installed my new shroud my temperature gauge is between 1/4th and zero (when i have the heater core open).
is this a problem or should i not be worried much?
i dont think its the thermostat since it operates fine during normal weather but... i guess ill take your inputs.
daytime:
![](http://i468.photobucket.com/albums/rr43/ouch617/sc300/20121016_132651.jpg)
night driving: (dont worry, i may not have been the one holding the camera)
daytime:
![](http://i468.photobucket.com/albums/rr43/ouch617/sc300/20121012_004317.jpg)
sounds good! and yea i remove my cluster all the time but thats not the issue ( i ran my car with out a shroud for the summer and it was running warm all the time) now that i have a shroud plus the additive its super cold.
ill try removing it and running a normal coolant/distilled water setup instead!
thanks all
thanks all
My 92 SC400 has always run at the second mark shown in your first photo for 21 years, never deviating under any circumstance. I guess is that you have something wrong and worth fixing.
Neofate
16
03-18-08 09:15 PM
