sideskirt hardware question
SORRY FOR THE GIGANTIC PICTURE....
Going to order the oem hardware to install the sideskirts on my car. Just wondering if I am getting the right things. This is a common sense thing but it doesn't hurt to double check.
Parts catalog w/ numbers:
http://lexus.sewellparts.com/oem-cat...C400-1998.html
![](http://lexus.sewellparts.com/images/oem/1400x1000/750064.jpg)
parts i have in my cart w/ quantity:
75494 - 6
75495 - 2
75867A - 8
75868B - 12
subtotal is $73.44!!!! seem about right.
75494 - 6
75495 - 2
75867A - 8
75868B - 12
thanks for the info. they still mount up just fine without them right?
do i need......?
6771-12070(2)
90189-04059(2)
90162-40035(2)
do i need......?
6771-12070(2)
90189-04059(2)
90162-40035(2)
i ordered all of mine stright from lexus for like $25.00, price seems very high for just some clips man
also I dont know why you need so many different part numbers,,,on mine there were only two kinds of clips,,,the ones that go into the bottom and the ones that attach the front face.
Might be best to just call your local dealer and order them by phone, that way if they give you too many clips or the wrong ones you can just return them easily, and im sure they wont be $80.00
ok lets see if i can remember exactly
the first hole right behind the front wheel well is just a hole for a bolt thread and a nut holds it in place, on the 92-96 body. for the 97+ skirts i got a small bolt with a washer and jammed it in the clip holder so the side skirt now has a thread for that first hole
the rest of the clips you can use as toyota intended
so i would get:
75494 - 4
75495 - 2
75867A - 8
go ahead and pull the 92-96 trim pieces off and you can see what all needs to be clipped in or bolted on
so i would get:
75494 - 4
75495 - 2
75867A - 8
albertldee
10-13-13 06:21 PM
