spacers for supra tt front rims
I noticed that my sc has TT rims and the fronts are rather too flushed. what size spacer would you all recommend to bring them out a bit and where's a good place to pick up some?
Thanks,
Sid
Thanks,
Sid
Honestly, if they're too flush it sounds like they're fine, but if you want them to poke I would go with 5mm or 10mm max. Make sure you get hubcentric spacers. I would do ebay and get the cheap ones if you're doing 5mm. If 10mm then I would go with the h&r ones.
