Longest lasting tire
Hey guys what is the longest lasting tire you have had on your SC300? Im sitting on 275/35/18 in the rear and 245/40/18 on the front with quite a bit of a drop all the way around. I'm planning on raising it to fix the camber situation in the rear though. I appreciate all input.
I have delinte on the rear 275-30-r20, soft compound and a lot meat exellent tire I have this one for 8 months, on the front 335-35-r19 carbon series again a lot meat soft compound I have this for 3 months I am lowered on megan coilovers and negative camber on front and rear I will say prob 1.5 deg on all four. ah they are cheap tires.
1JZ Single SC400
I would say any style Michelin rating above 400. I have always had great luck with them, not a particular model. I have had terrible luck with Khumo and Falken FK452's. This could have been contributed to worn out bushings and so on..
