Cluster Backlighting Bulb Socket Problem
Hey guys, I'm having this issue with my cluster on my 94 SC300. I replaced all 32 of the bulbs for the backlighting and most of them work no problem, but some dash lights like the battery stay on all the time. I do not have a problem with my battery or alternator, this has only been a problem since I switched everything to LED bulbs. The airbag light is on after removing the cluster which I know is normal and can be reset, but the battery light does not stay fully lit, just half way dimly lit when the car is running. Also, the orange low fuel light stays on all the time now too. Does anyone know if each bulb socket that twists on the back of the cluster where the bulb fits in have to go in certain places or all they all the same? There are like 4 different colors, blue, black, green, and gray but they all look the same, I switched some around and it seemed like it fixed some of the other lights that were constantly running even though they shouldn't be. Also, the airbag light stays dimly lit on the cluster when the keys are removed from the ignition and the car is off and locked. Anyone else have this problem? Thanks in advance.
The airbag light will turn on if you turned on the engine while the cluster was off. OLT made a DIY on how to reset it at LexTech.org, or you can search here. Also, the battery light, low gas warning light and airbag light are amperage sensitive warning lights. And since LED's have lower amperage than regular halogen bulbs, then they light up even when there's no problem. I actually just realized that now that you mention it, and has been running with all those 3 lights lit up ever since I converted mine to LED's. never really had time to look into it anyways, since I had plenty of maintenance to do on my SC. Lol
Oh thanks, its good to know I didn't break anything while replacing the bulbs and needles!
So should I just put the stock incandescent bulbs back in those 3 that are giving me trouble and keep the rest LEDs?
Yes. I'll do mine too, 'cause I hate too many lights on my dash, feels like Xmas tree in front of me since LED's are also too bright. Lol I must thank you too, 'cause I wouldn't have figured that out if you didn't create this thread. Lol
I was actually under my SC this morning looking for the engine ground thinking it was the one causing my battery light to turn on, 'cause I've had mine turned on since I bought the car, but that was because of a bad alternator and alternator connector wire. But 2 alternators later and a brand new battery it's still lit. OMFG I can't believe it took me this long to figure this out. Lol
Yo, I just fixed my low gas warning light and battery light right now. I just switched those 2 bulbs back to the regular filament, and boom, it's back to normal. Only thing I need to do now is reset the airbag light. Here's a guide for you;
http://lextech.org/forums/index.php?topic=9.0
lowlex96
05-18-11 12:23 AM
