No sound from speakers after carwash
Hey guy i was wondering if anyone had problems with the stereo on a 97 SC400 . My stereo was working fine for the past couple months and then today I decided to give a car a clean rinse at the local car wash. Right after I was done , I started the car right up and just like that the front speakers had no sound. I can hear the bass from the trunk speakers and thats about it. Would it be possible if water somehow got inside ? ALSO when I purchase the car , it had the "PREMIUM SOUND" installed and also a nakamichi head unit in the trunk as well.
It could be a fried amp or blown speakers? To check the amp follow the first link and look to see if there is any water/rust around the amp. Can't see any that's good news because that means that the speakers in the rear or front are blown. I had all my speakers stop functioning an it turned out to be that my rears were blown causing the front to no longer work. Perform a test with a cheap/small speaker to the back +/- terimals, if you get sound the speakers are dead. Follow the DIY in link two to replace the old with new speakers.
http://www.carstereoremoval.com/htm/...40092_00CD.htm
http://us.lexusownersclub.com/forums...-sound-system/
Steps for the front, although I would think they are fine, since the front do not get much sun/heat exposure.
https://www.clublexus.com/forums/lex...tml#post802171
Sounds stupid but you could also check the wiring to make sure nothing came unplugged. The ground wire for the deck could also be touching something or came undone. I had that happen to me several times with my Pioneer 7000
^ Possible if using an aftermarket unit. Had that happen to me a that I thought my unit was fried. From what I read he has oem nak unit. Follow teal's instructions as I have no experience whatsoever with oem speakers (never had any except for one car that had an amp for each speaker).
Sup2jzgte
09-02-08 02:18 PM
Shaar
07-11-04 11:04 AM
