Want RideSkinz to produce Clear SC Headlight Lenses? [Post up!]
#249
Several choices:
1.) Use some nice factory lenses (RideSkinz might make clear highbeams a bit later, as well as fogs...)
2.) Use Ebay black or chrome versions of the projector highbeam lights to match w/your factory lowbeams (As Ryan and I have done w/ our black sets. *Several examples posted below and in Ryan's prior posts.)
3.) Use lenses from Ebay projector lights on factory buckets as I've done with this chrome set below:
#250
[Here's a video of my clear highbeams- CinCity Designs isn't a company anymore fyi- Not advertisement]
Here you can see the clear lenses factory lights match up well with Ebay highbeams.
If Rideskinz produces the highs they should be a better thicker material, plus getting rid of the number codes:
Also, I suppose if you really can't wait for clear fogs to be made, you can swap over the Intrepid fogs as Tony Bui (below) has done, along with several others including user OneJay. I'd wait on the real thing since you have to trim a bit on the bumper and on the Intrepid surrounds, but they don't look half bad once installed if you can't wait:
#254
Hey Cali. I believe they are a pair of legit Supermades. Pulled from SC400TT's car.
So no, no cheap ebay setups here. If they were taken from ebay moulds, we would all have to modify them to fit our oem housings.
However as the moulds are taken from a pair of Supermades, they will fit directly on.
I think the most logical way to produce these would be to actually use the OEM lenses as the mold, rather than the Supermade lens - just a thought...
In any case, I'm down for a set - if this falls through, I'm going to make some glass ones myself!
