1993 SC 400 key/remote
I have the one button key/remote. It isn't working so I want to change the battery. I have made few attempts at opening it but I'm afraid to put to much pressure on the plastic case. Any suggestions?
Is it even designed to be opened?
Yes! Thanks a ton.
Update. Just so you don't think I'm a total idiot. Looks like the previous owner did a replacement. He did not replace the screw or the O-ring. He also glued it shut. I took a razor blade and went around the seem then it popped right open.
Will I need to go through some reprogramming process?
