Part fitment
Would like to know if the hood & fender off a 94 sc 400 will fit a 95 sc 400, also wondering if the white diamond pearl paint are the same color for both of them years because I found a 94 sc at the junkyard & it look to be the same color & I'm hoping it fits and the cold is the same, any & all input appreciated
The fender shouldn't be too hard to line up, just make sure all the bolts are in and see that the fender isn't bent. The hood primarily is where you're gonna have fun, lining up a hood can be a PITA. Make sure you have a friend w/ you when you install it. It'll make your life easier.
Paint codes for Diamond White Pearl is the same for both of those years, but be wary if either has been resprayed, all bets off, if not original factory paint. When installing / aligning might be a good idea to tape the edges of the new and surrounding area to prevent any stratches / knicks
Good luck!, & post up a pic of the results!
