Help with my passenger door!
I bought my 1995 sc while back, few things where wrong with it like the pass door, it will not open from inside or out, the other weird thing is that the window is going almost all the way down then gets stuck on something. has anyone else had a problem like this? if so or if you have any idea what i can try to do to fix it please let me know. im having a hard time getting the panel off since i can not open it.
thanks!
thanks!
Don't break the panel, it's hard to find, and when you find it, they're expensive.
Door handle is something that breaks all of the time on older SC's. Have you tried picking the lock?
As for the window, I had this problem too. The window was not aligned, it was leaning, so it was scraping against the rubber thing. Took apart the door, and re-bent the window supporter and it works.
door window
ok if ur door dsnt open inside or outside it because u need a door lock mech, junk yard 25$ in order to open it there is a screw behind the door handle, u have to remove the black plastic cover there is a gold screw the phillips will reomve , next u have 2 under the arm rest little harder to get to sence u cnt open door, u do risk breaking ither a windiw trim or a door panel beause u cnt remove the 2 screw n front of door and 3 at bottom not to mention the door panel tucks n undernieth the window trim so b very carful if by some way u can remove door panel a little lit u will see 2 cables 1 w a blue tab on end anf the other with a clear plastic on end the 1 w blue is for door handle the other door lock manualty unlock door and pull cable w blue to open door. then u can remove door panel completly and see whats going on inside it can simply b a broken clip, or the auctual door lock mechanisum is bad and needs to b replace if so u have to take apart the whole door to remove it window has to come out , rails, outer trim mirror window reg its a pain,
now 2nd the window going up and down if it stops like 1 inch b4 the bottom and a little sticks up above the weather stripping that is because the regultor fits but id from the wrong yr of car its why its off a ince, if it goes dwn and up fine but slow, then it can b a motor going out, or simply just some grease on rails might help so there u go those r ur possibilty i deal with this all the time so i knw a little about it. good luck and if it is regualtor then u have to replace the whole assembly to make it go all the way dwn if it bothers u that much
phill
SC- 1st Gen (1992-2000)
13
12-29-04 10:48 PM
