SC- 1st Gen (1992-2000)
Oh happy day....... I have FIXED the SPEEDO and TACH
Old 01-21-13, 06:25 PM
thebadz32
thebadz32's Avatar
Originally Posted by Jostar
I e-mail you as well regarding this Issue!!! OMG, Price please on repairs!!! Thank you so much for your dedication & hard work!!! You sir!! have my respect!! artzors@yahoo.com was my e-mail...
I beleive the pricing was listed on his web site
Old 01-22-13, 06:40 AM
Jostar
Jostar's Avatar
Link please...
Disregard.. I found it...
All I have to say is.... my respect to this gentleman for doing R&D for a platform that is very old..
Old 02-20-13, 10:55 PM
O. L. T.
Keeper of the light
O. L. T.'s Avatar
Time for an update. I've been inundated with inquiries about how the research is going and I've got it down pat I believe. All I have tried have been successful.
Here's an example of some changes below. I've beefed the caps up from 25 v to 50 v so they are completely impossible to get hot and overload now. You can see the huge difference in how much better they are. They are the same uf, just higher voltage which means beefier and more heavy duty. I'm still doing a complete rebuild of the board components in most cases, but many improvements are designed in.
Old 02-21-13, 05:57 PM
O. L. T.
Keeper of the light
O. L. T.'s Avatar
More look at some of the partial rebuild.
Old 02-21-13, 06:10 PM
Li Ls4
Li Ls4's Avatar
awesome work, cant wait for the end result. its going to help a lot of ppl here
Old 02-21-13, 06:25 PM
O. L. T.
Keeper of the light
O. L. T.'s Avatar
Here is before and after on the tach for the caps. Keep in mind the caps are not actually what need to be replaced here, but we have seen how they can cause issues when they are older (ECU ring a bell?) so as with everything I am in it needs to be bulletproof as possible.
BEFORE:
AFTER:
OK, so you can see how I have beefed the caps up to higher tolerance. They will handle heat better AND last longer than the stock caps so this should be a one time only deal. They will never need replaced again after I have modified it. Partially because they are twice as stout as needed in this application and partially because this car won't exist at 40 years old. Sure a few will, but let's be real, yes? Ok so a permanent fix here with the modifications and all new parts.
When you rebuild this and the computer chip comes out, you have to charge the caps before installing them with the computer chip out, then charge the pins properly (in the correct order) when you stick the chip back in or you will kill the chip since it is a mosfet gate chip. The caps will spike the chip. It has to be done perfectly. The gates in the chip will just fry if the caps charge through the chip and spike the gates.
Old 03-28-13, 02:55 PM
O. L. T.
Keeper of the light
O. L. T.'s Avatar
I wanted to update this since I finally ran across a cluster with a bad MAIN mobo instead of a bad motor mobo. This is one out of more than 20 or so. I will have to keep track of if this happens again so we have a failure rate study, but as of now it is still a one time thing. I'm also trying to keep up with it myself so posting here.
Old 03-28-13, 07:23 PM
SCYAL8R
SCYAL8R's Avatar
I'm willing to pay to have my cluster restored. I have a 92 with 190k or so and tach and Speedo are dead. And one needle is dead.
I couldn't find a website. Is this gentleman the one on eBay advertising repairs where you send him the cluster?
Old 03-28-13, 07:38 PM
SCYAL8R
SCYAL8R's Avatar
So I found the site and made an inquiry. If I'm able to use his services I'll do a before and after.
Old 03-28-13, 11:25 PM
xxtoobsxx
xxtoobsxx's Avatar
Wait...so you have a manual tranny cluster? lol...good job!
Old 03-29-13, 09:04 AM
Clean400
Clean400's Avatar
Having my cluster, needles and climate rebuilt by you has been on my list for a long time. Keep up the good work
Old 04-26-13, 08:07 AM
O. L. T.
Keeper of the light
O. L. T.'s Avatar
Documenting:
Failure on IC1 in the upper left of this pic.
Attached Thumbnails Oh happy day....... I have FIXED the SPEEDO and TACH-img_1067.jpg
Old 07-25-13, 11:55 AM
psychenry
psychenry's Avatar
My 1993 SC300 (112,000 mi.) tach stopped working for a day or two (needle not moving), then was working fine yesterday.
Comments?
Old 07-25-13, 03:04 PM
O. L. T.
Keeper of the light
O. L. T.'s Avatar
Yes my comment would be why did you post three threads on it and bump this one with the same comment of the other threads. The thread is pretty clear.
Old 07-25-13, 03:21 PM
Ali SC3
Ali SC3's Avatar
Originally Posted by O. L. T.
Documenting:
the chip just went kaput? maybe a cap or something on the power line isn't doing its job or shorted it. you are right that seems a bit odd of a failure.
its probably a lm2907 or 2917 from a quick search.
http://www.ti.com/lit/an/snaa088/snaa088.pdf
Quick Reply: Oh happy day....... I have FIXED the SPEEDO and TACH
