SC- 1st Gen (1992-2000)
Anyway to make door easier to close?
Old 01-29-13, 12:15 PM
sidwin
sidwin's Avatar
Default Anyway to make door easier to close?
My doors are extremely heavy to shut. I was at a junk yard this weekend and saw one that was extremely light to open and close. What has to be replaced or fixed to make my doors do that?
I was so surprised that I checked out another sc they had in the lot and that door was light too. My buddy came with me and he owned two sc and he said the same thing. I wonder if it is the spring/bearing in the hinge.
Thanks - Sid
Old 01-29-13, 12:24 PM
sj408
sj408's Avatar
Does it still operate smoothly? just heavy in weight?
or does it seem binded and possibly make a popping noise bout halfway?
and is it both doors?
Old 01-29-13, 12:40 PM
sc400ka
sc400ka's Avatar
have you tried lubing the hinge?
Old 01-29-13, 01:31 PM
Tabaka
Tabaka's Avatar
Remove doors and go mad max style
Old 01-29-13, 02:25 PM
SC400slide
In Recovery Mode
SC400slide's Avatar
Spray liquid wrench on the hinges, like, A LOT!
Old 01-29-13, 02:44 PM
sj408
sj408's Avatar
Guys, Going to town with lube isnt always the answer with these.
As explained in 100's of previous threads there is a none load bearing "collar" if you will that causes the hinge to constrict at times and prevent free movement.
OP, provide more info and someone will help you, as im sure youve heard of lube before
Old 01-29-13, 03:24 PM
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
I would clean them on all sides with a degreaser real good then allow to dry. Then apply WD 40 all over them while opening and closing. If they are popping remove the 10mm bolt on the hinge. Just this one...
Old 01-29-13, 05:46 PM
TheAzn
TheAzn's Avatar
Weld them shut and climb thru the windows.... because racecar
Luxury cars, heavy doors. As long as they work right.
Old 01-29-13, 06:12 PM
sidwin
sidwin's Avatar
i thought it was normal to have a heavy door until i saw the two at the junk yard. my supra door probably weighs pretty close but i'm guessing the way the hinges operate makes the difference. those two sc doors felt like a normal door. we were both surprised. made us think it might be a spring or bearing....
Old 01-29-13, 06:19 PM
ASTERiSK
ASTERiSK's Avatar
Either get carbon fiber doors or start working out.
Old 01-29-13, 06:34 PM
2jznosht
2jznosht's Avatar
Haha this was my exact thought
Old 01-29-13, 07:47 PM
xxtoobsxx
xxtoobsxx's Avatar
workout more buddy...if that doesn't help, eat Alot, take steroids and workout some more
Old 01-29-13, 08:02 PM
sidwin
sidwin's Avatar
my 5 year old rides in the car and he has a hard time closing it. he's a little young for steroids but he is a good 60 pounds or so... He doesn't have any problems shutting the supra's door either.
so i'm guessing no one has tried replacing the spring or bearing.. guess the next time i go to a junk yard, i'm going to have to take one off and see if that's a fix. The door doesn't feel like there is much drag but there is a little bit of drag right when the door hits the striker. my good friend is a body man so i'll get him to take a look at adjusting the striker.
if i didn't see two other sc with their doors shutting normally, i wouldn't have believed it either.
Old 01-29-13, 08:37 PM
Kalogerus
Kalogerus's Avatar
My passenger side opens/closes much smoother than the driver's side. I am not surprised given that the previous owner is a Shaq looking like dude and I bet his door shutting was pretty harsh even without trying.
On a second thought, the entire passenger side wasnt as beat up as the drivers side lol.
Old 01-29-13, 08:42 PM
jwin
jwin's Avatar
http://www.jkwebdesign.co.uk/lexusclub/doors.htm
This should help
Quick Reply: Anyway to make door easier to close?
