My drivers side window wont roll down!
I replaced the entire wiring harness 2 days ago because only my locks would work, now both windows work. The only problem now is that sometimes it works great, sometimes it doesnt work at all.
New problem, I was driving around with my windows down for the first time ever, I pulled back into the driveway and my window wouldn't roll back up! I plugged my other switch in and still nothing, it eventually would go up about an inch then stop then another inch then stop and so on. I finally got it rolled back up and after that it worked perfectly. Today I had my window down and it started to rain so I went to roll it up and the same thing! After I got back home it finally rolled back up. I am pretty sure it's a bad connection somewhere but does anyone know something in particular that could cause this?
Does anyone know how the driver side window switches work? What happens in the circuit when the window continues down after you let go of the switch? I've suspected that the gremlin is in there, somewhere.
My windows wont roll down
Ok so my drivers window will roll down and so will my other windows but I cant roll down the windows from the drivers side. Would it be the wires under the panel? Or something else? let me know asap please.
