Speaker Question
I was wondering if the door speakers in a 95 sc400 are the same as the ones in the rear deck if you take them out of the mounts. Just the speakers themselves.thanks John
I put new 61/2 inch kickers in the rear deck and a few months later my amp went bad. I was told it may be becuase of the aftermarket speakers.So I was going to go back to the stock ones.
Have you located/looked at the amp for any water/rust around the area? This may have caused the amp to fail and not the 6" 1/2 speakers.
Booramey, went back to your OP (new stereo problem) were you mention the speakers are making a thumping sound. Try this test turn the TREB **** down/BASS **** up and viceversa also use the FADE/MID ***** in trying to locate the area the thumping is coming. It could be your subwoofer has blown causing the thumping you're hearing?
i installed 5,25 inch Speakers front and rear, with some little mods was this no problem. My first idea was also 6 1/2" to install, but the are too much mods for install and you need for the rear flat speakers and in front a complete new housing and a modified door panel. This is not a 15min action ![Big Grin](https://www.clublexus.com/forums/images/smilies/biggrin.gif)
rear:
![](https://lh4.googleusercontent.com/-55z5YTLfG_g/TYO9_dJ3KxI/AAAAAAAADbA/k4BwMdLKTeM/s900/K800_IMG_6690.JPG)
![](https://lh6.googleusercontent.com/-UD74DjJWMeI/TYO99GY674I/AAAAAAAADbA/jL4IadFZcJQ/s900/K800_IMG_6670.JPG)
![](https://lh4.googleusercontent.com/-V8D_zNASSJY/TYO9-FsIyzI/AAAAAAAADbA/z2SJzw12v7k/s900/K800_IMG_6672.JPG)
front:
![](https://lh5.googleusercontent.com/-3Nuie2cum1o/TYZkUhSEfwI/AAAAAAAADfA/3Qo9XUaHLTE/s900/K800_IMG_6750.JPG)
![](https://lh4.googleusercontent.com/-gib_XO8qrIs/TYZkYM7pYQI/AAAAAAAADfA/6jcw59VGL8c/s900/K800_IMG_6755.JPG)
![](https://lh6.googleusercontent.com/-YovbTIKjhyU/TYZkXEFfPhI/AAAAAAAADfA/63HeBraCJ3g/s900/K800_IMG_6754.JPG)
greets
Tom
rear:
front:
greets
Tom
Alphaman19
02-16-16 11:30 AM
RolxuSC400
09-28-08 04:02 PM
Zemmy
02-24-03 06:21 AM
