Part number Help PLEASE :uh:
Sorry to have to make a thread for this... ![Sad](https://www.clublexus.com/forums/images/smilies/sad.gif)
I have been searching on CL and the internet for hours to find this darn part number.
Sewell couldn't even give me the #.
No exploded diagram that I've found anywhere states what this part is.
Is it maybe just some generic hose cut to length?
This black rubber hose which attaches from the Power Steering Reservoir into the metal power steering lines. Highlighted in YELLOW![Uhh...](https://www.clublexus.com/forums/images/smilies/1387914497.gif)
![Part number Help PLEASE :uh:-d8lvr2l.jpg](https://www.clublexus.com/forums/attachments/sc-1st-gen-1992-2000/500929d1683165969t-part-number-help-please-uh-d8lvr2l.jpg)
Hose "11"
Hose "11"
![Part number Help PLEASE :uh:-ragds4u.gif](https://www.clublexus.com/forums/attachments/sc-1st-gen-1992-2000/500930d1683165969t-part-number-help-please-uh-ragds4u.gif)
Thanks for the input guys. Still hunting for this damn thing...
Any auto parts store carrys "power steering return hose", which this hose SHOULD be... except for one thing: the stock hose has a plastic hard shell inside of the rubber hose. If you were to cut it in half, it would be a plastic tube wrapped in rubber.
Any / all of the PS return hoses I've seen are just rubber only, not rigid. You could squeeze them closed whereas the stock SC300 hose is as hard as a rock.
Makes me think that is needs to hold more pressure then just PS return hose can handle. Am I wrong?
This hose goes from the PS reseviour to the high pressure metal line to the right of the PS pump.
![Part number Help PLEASE :uh:-hchz0vi.jpg](https://www.clublexus.com/forums/attachments/sc-1st-gen-1992-2000/500883d1683165950t-part-number-help-please-uh-hchz0vi.jpg)
![Part number Help PLEASE :uh:-8mze8if.jpg](https://www.clublexus.com/forums/attachments/sc-1st-gen-1992-2000/500884d1683165950t-part-number-help-please-uh-8mze8if.jpg)
Im nearly 100% positive that my PS cooler (which i deleted) is tied together with a piece of regular PS hose as well. If it wasnt dark id go take a pic
Thanks for the posts! I really appreciate it.
This too is what I originally thought since it is coming off the high pressure metal lines; however, I've been told by a few folks that this is just a normal PS return hose.
I'm sure you didn't erroneously post this comment... so can I ask if you're 100% sure?
The hose is held on by two metal clamps and does "return" PS fluid. Is this not normal PS return hose?
The hose is not given a specific part number on Lexus diagrams because like previous posters said, this hose would come attached to the metal high pressure PS lines if you bought them.
Due to this I could see how they could be high pressure.
But I also see the argument for it being a normal PS hose held by clamps.![Uhh...](https://www.clublexus.com/forums/images/smilies/1387914497.gif)
Thanks! I do think you're correct on the plastic being for shape / form. Because... how would some plastic the thickness of a nickel be able to make a difference in holding pressure in the hose. It's just normal plastic that would easily shatter if you hit it moderately hard.
counteru
02-02-20 12:40 PM
montytx
04-09-18 04:27 PM
mirekti
03-11-18 08:54 AM
horent135
Performance & Maintenance
04-14-12 07:59 PM
