Antenna Removal
Antenna Removal
Decided to replace my oem antenna with an after market soild rubber model. Well I thought all I need to do was loosen the slotted retaining nut on the top of the base. I have been using a slotted screw driver and hitting it with a hammer at an angle. Can't get it to budge. I'm knocking the crap out of it. Is this the correct way to remove the oem antenna or am I messing it up?
That seems to be the correct way https://www.clublexus.com/forums/sc-...is-broken.html
Although I would use an item such as a watch case opener like this
http://www.harborfreight.com/watch-c...ner-91550.html
SCpwner
10-18-07 02:19 PM
