120 and 100 amp fuse replacement - Cables connected to fuse module
So I got the fuse module case thing out of the fusebox, removed the screws and replaced the fuses. I damaged the little plastic tops of them while working in there and I wanted to be 100% safe. It was a half hour or an hours worth of work I didn't intend because I was a little clumsy. Knucklehead me.
So, I'm ready to put the module that has the 120 and 100 fusible links in it back together, and I wanted to be 10,000,000% sure. There's one cable that goes to the 120 amp fuse and 2 that go to the 100 right?
I searched around a bit but I couldn't find a specific document that detailed all this. For the people who have done this replacement, is this correct?
Thanks.
Thanks.
