Should I get this steering wheel?
Hey CL! Their is a wood grain steering wheel for sale on ebay for $150.
Is it worth it?
Would I be able to somehow relocate my cruise control?
What are the downsides to replacing the factory steering wheel?
Here is the wheel
-Comment your thoughts-
Is it worth it?
Here is the wheel
i like that wheel and $150 is reasonable , but you wont have an air bag as said above ,,,,and i couldnt live with my air bag light being on all the time.
Id say find a newr model lexus wheel to swap in properly.
^^^^i got the rx woodgrain wheel and its the best choice for our cars i think , although they can be hard to find and a bit pricey at times.
I put a energy hub and wheel in my car a few months ago. I lost my cruise control when I did my GTE swap so I was not too worried about that. I had to buy there quick release hub to be used as a spacer so my horn button would clear the nut that holds the hub to the column. They offer two size quick release adapters and I went with the larger one just to be sure. It took some getting used to because the turn signal stalk got spaced pretty far back from the wheel. Maybe this would be better if I had used the smaller quick release. I also could not get the horn to work because of the clock spring. The connector on it is pretty large since it has the wires for the cruise control. With some other cars in the past I have just drilled a hole in the base of the hub to allow the connector on the clockspring to still be used. They give you some universal adapters but I couldn't figure it out. I am very happy with the steering wheel, its seems to be made of better quality materials. Its not flimsy like some of the cheaper wheels I have seen. I have the leather one.
Chicago Lexus Club Moderator
If your current steering wheel is messed up just get it re-wrapped. That's what I did and it looks perfect without making my car into a rice rocket.
