Basic MUST HAVE tools for trunk of Sc400?
All the tools I carry with me. 3/8 ratchet, complete wreches up to 18mm, sockets from 8mm to 20mm, extensions, size adapters, still have my large sockets that can fit the axles, 3ft breaker bar, combination screw driver with torx bits too, pliers, channel locks and some more that is thrown in the bag. And I still carry my oil filter wrench and stuff.
I go to junkyards often. Plus I'm always doing little things to my cars. And I'm quite worried everytime I drive if I breakdown somewhere for something stupid.
I guess I carry more than just "basic" tools... But altogether, it's in a toolbag. But even the basic tools can cover most maintenance works. I use tools beyond what they're intended for if I can if I don't have proper tools. If it works, it works.
I also have this since I didn't have a spare wheel to clear my brakes up until recently.
I usually keep a hydraulic jack, breaker bar, and a small socket set handy. I also have a handful of oem lug nuts stashed away in the event of a flat, I'm always a little iffy about limping away from a flat with "tuner" lugs on my spare.
At the very least you'll want a 10 and 12 mm socket and a phillips and flat head screwdriver.
I had to pull my engine thermostat out on the side of the highway once. Thank god Lexus had a courtesty kit with a 10 mm wrench in it. Also thank god I had my jack, jack stands, and some 2x4's in my trunk otherwise I would've been stranded in Merkel TX. Never attempt to make a big drive if you know something is going out in your car.
i have a craftsman toolbag loaded with sockets from 8mm to 22mm,testlight,voltmeter,screwdrivers and an obd scanner.and a hugh breakerbar.cant forget a box of nitrile gloves.i'm a forklift technican and this bag has been with me in all my cars even the new whip.just in case
The sockets you will need are 8,10,12,14,17,19 and 21mm to take off most bolts on the SC. Just buy a 10-19mm 6 point socket set from craftsman. It'll be cheaper than buying individual sockets. Unless you want to buy Snap on tools, then I would start with only the sizes you need since 1 snap on socket cost as much as a craftsman set.
You'll also need a ratchet with extensions, a set of wrenches, #2 phillips screw driver, a flathead screw driver, a set of metric allen keys, some pliers, a cutting tool, electrical tape, and zipties are always nice to have. Don't forget to keep a flashlight in the car.
I also have a breaker bar and 21mm socket to remove the lug nuts since I don't have the stock lug nut wrench.
I have sockets, ratchets, wrenches, vice grips, electrical tape, a crank pulley tool. pliers, screwdrivers, a monkey wrench and probaly some stuff im forgetting...seeing as how the storage in my apartment is tiny tools are a better fit in the trunk
