So on my driver side headlight the tab broke and now the headlight isn't sitting right so the projector isn't shooting the same as the other, I'm just trying to see if anyone can help with this. I need a driver side headlight either full or just the back plastic black peice. I'm new so not sure if there's an exact location to post this thread.
That tab shouldnt affect the projector aiming. The two bolts on the side are what really holds it up. You can bolt those down and the headlight sits in place! You probably need to adjust your projector properly!
Well the tab is useful when aligning your headlight so the projector aiming is even on both sides. As far as just being securely held down, the two nuts on one of the sides really holds it down.
Your right the headlight sits fine and all no movement but the angle that the beam aims is off from the other headlight
