Door sagging
Door sagging
Can anyone fill me in on how to fix this issue. I know our doors are heavy and after time they tend to sag. Don't know if taking it to body shop is the best option. Thank you
Get a jack and lift the door up up a bit in the center of it. Then loosen the bolts on hinge, dont remove. Then jack door to desired height. Tighten bolts and then you should be good. Thats what I did. You can use the oem jack if you dont have a reg hydraulic jack.
Just keep in mind, any fix you have done to the hinge, it will most likely be a temporary fix. Getting a new one would probably be costly, but having to re adjust the hinge is also a hassle.
this works for sure
