AnyOne know if these wheels will fit
I have stock suspension. Thees a set of 18 amg wheels he says are 245-40-18 and 255-40-18 heres a picture from google and the actual picture of the rims on the car. I dont know offset please let me know thanks.
hmmm that sux these are cheap prolly spend 100 on adapters but if they use the lug studs (which i assume are the whole stud is bolted from the wheel into the hub right?) I guess its too much of a hassle.
Mercedes bolt pattern is 5x112
Lexus is 5x114
Adapters are going to run $100-150 a pair (x2) = $300.
I use to own a w210 Mercedes before my SC. After reviewing your photo, this offset is probably mid to high +30's. An adapter is probably 20mm (3/4") inch.
Correct, Mercedes uses a 3.5" long (roughly) stud that goes into the hub... vs our Toyota/Lexus which has studs coming from our hub and we use a traditional lug nut.
Your cheap wheels just became very expensive.
Lexus is 5x114
It seems like everybody has answered your question for the most part, but for future reference if you find some stock rims that you think might look good this site has the lug pattern and center bore for most vehicles (except Mercedes coincidentally lol).
http://www.ezaccessory.com/Thread_Si...Guide_s/12.htm
